I don't know how to use the sohc harness (I bought my bpt with an uncut harness), but that middle black thing is your boost sensor and increases the injector pulse when under boost. So not hooking it up WILL result in boom.
Look and see what others have done. I know others have converted a soch harness into a dohc one by adding wires and others turn a dohc one into a turbo one by adding wires but I don't know how.
BTW that boost sensor breaks easy and is expensive to replace (it's part# FE70 18 741A "3 way valve" if you need a new one)
The other two wires I'm not sure as I can't see enough but the top one might go to the trans.
that White plug sensor looks like it appears it should plug into a sensor that is right by the Thermostat housing area on the front of the engine..
1993 MX-3 RS,FULL BLITZ KIT(PROTOTYPE)17"10 SPOKE RIMS,SOHC 1.6L. http://www.cardomain.com/ride/2189811
nobodyhere671 wrote:would it work if i took the wires coming out of the boost sensor and matched them to the same colored wires in the harness?
Your on your own there the NA harness doesn't have the wires in it for the boosted specific parts.
You do have a gtx ecu right? Does it have the cut harness stubs? If so you could match the boost sensor wires to the ones on the proper ecu harness then hook up all the other wires (using a couple wiring diagrams) to the bpt harness stub, just a thought.
I used a protege lx wiring harness for my bpt swap ill take a look today and let you know how i have it connected. Franko has used the sohc so you might want to get in touch with him. The protege lx harness bolts in pretty easy just need to swap the injector harness from an NA bp as well as the tps(i just swapped throttle bodies) and just buy a new 2 wire o2 sensor.
94 green rs
92 black gs project bpt. daily driven bpt in a gs...lovin the boost
1st pic looks like the plug that goes to the oxegen sensor.
2nd pic -> no idea
3rd pic -> a temperature sensor (on the sohc it's on the top of the intake manifold plenom, on the DOHC BP it's on the drivers side)
PM for info
