need a tranny to hold 450wHP
se7en
Post by se7en »
okay folks, I want to be the first in the 9's running the kl series engine.
the power end of it is easy (relatively speaking) I will run a de with ze? heads and de valetrain, and 20-21psi boost.
running a turbonetics 60-1 t4 .63 a/r making 450-470whp
okay, here's my problem.
the tranny.
I know that I will need tough axles, but the most problem is the launch.
do I have to buy the quaife lsd? is there a more cost effecient lsd that will hold that power?
I read somewhere about welding the diff or something?
also, it doesn't have to last forever, but at least 10 runs for tuning , then I can turn the boost back to a more realistic number :)
is there straight cut gears available for the g-series trans?
I am aiming for a 1.55-1.7 60 foot time to get the number with 26X15X10.5" drag radials.
I may launch and make the pass with less boost, and use some spray at the top for the runs, I haven't decided yet.
so, any ideas tranny gods?
lets make history :)
as far as I can tell, 10.80's is as fast as an mx-3 has run in street trim FWD(done by rafi)
and that was a bp.
7
edit: would it help maybe to lower the front and raise the backend? to keep the weight in the front...
atlantamx3
Re: need a tranny to hold 450wHP
Post by atlantamx3 »
se7en wrote:as far as I can tell, 10.80's is as fast as an mx-3 has run in street trim FWD(done by rafi)
and that was a bp.
That was not a BP, but a FE3.
~Perry
Please visit
http://www.mx3-atlanta.com
se7en
Post by se7en »
oh yeah, that's right...I knew that......my mistake :)
7
fieromx3
Post by fieromx3 »
450whp will not get u into the 9's
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
se7en
Post by se7en »
If I can stick off the line, then 450Wheel HP will get me into the 9's.
just for example(I know these things are usually generous):
http://www.race-cars.net/calculators/et_calculator.html
using that link as an example, using 2200lbs car with 450WHP runs 9.88 best case senerio.
I think that if I can stick it I will get close.
ps. I am not just some noob...I have been racing 10-11 sec cars for 8 years now. :)
so lets see what happens.
back to my original question.....can I get straight cut gears for this tranny? other recommend tranny upgrades?
(g-series specific)
thanks
7
projectB10
Post by projectB10 »
OK - Check out the following link
http://www.mazdas247.com/forum/showthre ... t=3rd+gear" onclick="window.open(this.href);return false;
The link provides some info on a various options for upgraded gear sets suppled by PAR out of Aussie. Big dollars for a genuine solution If you are serious about your 450wHP goal
Aston Wards
Post by Aston Wards »
I know this may sound random, but have a read through the loooooong TPS thread, KiwiMx3 was building a drag MX3 and posted some info in there...., actually, have a check thru some of his posts, there's tidbits of info everywhere lol! most of his stuff was homemade or custom-made
91 Eunos Presso KF-ZE
89 Nissan 300ZX TT 2+2
90 Nissan 300ZX TT 2+0
se7en
Post by se7en »
I did a search on kikimx3, and found nothing.
is that on mx-3.com?? or is that a probetalk or mx6.com person??
se7en
Post by se7en »
nevermind, I found it :) (kiwi_mx3)
heh.. thanks for the info..
7
kiwimx3
Post by kiwimx3 »
custom straight cut gears are made by a company called RPM engineering in auckland
New zealand for the mazda gearbox P.O.A.
first and third gear are the weakest link, a GTX third seems to be the strongest factory gear
so far.
I have bellhousing plates that remove the motormount stress from the gearbox assy which stops
a lot of cracking of the gearbox. my mazspeed lsd redrilled for extra arp bolts seems to be fine
so far.
I currently pull a 1.8 60' with a custom front end and shocks, if i was to run a wheelie bar i could
cut that to a 1.6, jacking the rear does nothing and 1000 lbs springs is scary on a short wheelbase
car in the topend.
Matt.
se7en
Post by se7en »
1.8 60' that's not bad....1.6 is what I will need to run my time...
what E.T. do you get? MPH?
thanks for coming out of retirement eh!!
7
projectB10
Interesting - Kiwi_mx3 and Kiwimx3 :?:
whats the deal with the user name? Kiwi_mx3 had plenty to contribute (granted - not for a long while) and all of it bloody useful.
So who is Kiwimx3?
kiwimx3
Post by kiwimx3 »
currently a best of 12's @ 115mph and thats if i have traction.
My bellhousing is machined 6mm and i have a plate
( ever seen how the v8 motors are mounted in tube chassis )
setup that picks up the front mount and the diff housing
also i have a modified 626 mount mounted to the rear of the
plate and it picks up the rear chassis member that the steering rack
is mounted on.
kiwimx3
Post by kiwimx3 »
projectB10 wrote:Interesting - Kiwi_mx3 and Kiwimx3 :?:
So who is Kiwimx3?
Its me matt the same guy, my old account is locked and the only way to get a new one is this.
and to post a answer to the guys questions.
does that answer your question ian?
projectB10
Welcome back Matt :D Great to see you back on the forum. You have been away?? Not inside but overseas ? :lol:
12's and 115. You have a lot to tell us about.
Return to “Transmissions”
