what oil is best for boosted ze
- PWRD_BY_HKS
just like the questions asks... let me know which one ... and WHY????? i heard i shouldnt use synthetic.. just 10-30... considering the weather down here is HOTTTTTT!!!!!! for the most part...
jdmx-3 KID OF THE ![Image](http://img118.imageshack.us/img118/8885/3kidkn5.jpg)
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
- mitmaks
Re: what oil is best for boosted ze
as long as the clearances in the engine are the same you still can use same oil as you'd normally use in N/A engine.
- se7en
hey powered.....does your stock clutch slip?
my exedy one does, and it's new.
- XxantwawnxX
i know its think but ive only ever used 20w50 in my ZE motor boosted and NA. I jsut bought it once and never had any probs so i kept getting it. I use castrol high miliege... never had probs ever.
se7en wrote:hey powered.....does your stock clutch slip?
didnt i tell you stock clutches slip? (when in full boost)
lol
-hec
- se7en
yup ![Smile :)](./images/smilies/icon_smile.gif)
I learn everything the hard way![Smile :)](./images/smilies/icon_smile.gif)
7
7
- PWRD_BY_HKS
No bro my stock clutch does not slip but then in again I'm at 3 lbs so.....
Damn antwan 20-50 weight that's nuts
VICTORIA RACING
VICTORIA RACING
- se7en
3 pounds of boost???1!!1!?1??one!!one!!??
that's it? all that work to get only 3psi?? turn it up man!
just jokes......maybe
7
i like 7 psi can you tell by my nick...?![Smile :)](./images/smilies/icon_smile.gif)
7
- PWRD_BY_HKS
yeah ...but the thing is right now we dont have a track open ... since our old race track shut down and the new NHRA track wont open till april or some thing like that i really dont need more than that for daily driving... once we start racing for money ... thats a different story you know....
VICTORIA RACING
VICTORIA RACING
- se7en
true lol ![Smile :)](./images/smilies/icon_smile.gif)
I was mostly jokin![Smile :)](./images/smilies/icon_smile.gif)
7
I was mostly jokin
7
Our track opened
but im not boosted.. BOHOO LOL
ill re boost in a few months, slowly getting my savings to get a real good turbo![Very Happy :D](./images/smilies/icon_biggrin.gif)
thats all i need actually.
3 psi and 5 psi is a huge difference in power
get some millenias and you wont regret it.. except for gas mileage lol
-hec
- fowljesse
Dinosaur oil does dissipate heat better than syn, but I don't know anything about turbo's and their needs. Syn holds up better against thermal breakdown.
rotillea 15-40 i think thats how its spelled.... works wonderful for boosted cars
- tehbrookzorz
- se7en
ya, it is diesel oil, but, it is also one of the only 'over the counter' oils(read cheaper than racing oils) that is available that contains the anti wear inhibitors in it still...Since the 'big three' car makers have been putting roller cams, and larger footprint lifters in their engines, and better materials in the blocks themselves, etc, the oil makers have been cutting back on the expensive wear inhibitors added to the oils.
Rotella T has extra zinc, and other things that help with turbo bearing wear because a large number of diesel vehicles are turbo charged.
We recommend it in all our 'old skool' rebuilt engines that we sell at my shop nowadays.
Just my 2€ all..
cheers
7
Just my 2€ all..
cheers
7
