323 awd -> MX3?
war_spider
323 awd -> MX3?
Post by war_spider »
hallo,
does the 323 AWD (BP-T GTR/TX) fit @ a MX-3?
i´ve seen a american MX-3 BP-T with AWD...
in germany no one knows... no one whats to know... so boring... :roll:
greetings Rainer
-= loud pipes save lifes =-
KL-ZE inside!
Flyer
Re: 323 awd -> MX3?
Post by Flyer »
Yes.
Custommx3
Site Administrator
Re: 323 awd -> MX3?
Post by Custommx3 »
WOW... thats all I can say.
MOVED from Suspension/Brakes/Wheels/Tires
to 4cl tech.
war_spider
Re: 323 awd -> MX3?
oh sorry my misstake...
@Flyer:
complete change? including handbrake, exhaust, engine, gearbox, shiftingbox, suspensions (does fit plug´n play cause same holes...)
does anyone @ this board does it?
V6 with 323 AWD do not fit or? caus gearbox difference :(
KL-ZE inside!
Custommx3
Site Administrator
Re: 323 awd -> MX3?
Post by Custommx3 »
The motor will bolt up to a 4cl tranny. The v6 will not bolt to the AWD tranny.
Also, you cant use the AWD system without lots of modifications. Its not a plug-n-play system by any means. Remember, your gas tank is where the driveshaft would go.
war_spider
Re: 323 awd -> MX3?
thats what i mean... only fitting i remember was the 626MPS prototype AWD... (KL-ZE bi-turbo 280 hp @ 4x4 )
mhm also buy a B6 and do a fun work :D
gas tanks can build new up ... BP-t engine into the mx and complete drivetrain and handbrake and so on :)
KL-ZE inside!
jamesmx3
Re: 323 awd -> MX3?
Post by jamesmx3 »
woudn't you need to transplant a bit/a lot of the trunk floor to fit the rear diff?
1997 1.6 16v DOHC uk spec gs, 17" wolfrace triad, 2.0l probe s/s header magnaflow high flow cat, powerflow custom catback, CAI, zx2 struts w/ -40mm lesjofors springs
http://www.uk-mx3.com" onclick="window.open(this.href);return false;
Aston Wards
Re: 323 awd -> MX3?
Post by Aston Wards »
Yeah, i think there's a couple of AWD RS MX3's on here, maybe they can help?
If you're wanting to stay V6, then you may want to look at the Mazda Capella wagon, or the Mazda Proceed/Suzuki Vitara (early models used the KF engine), they are probably JDM-only models though
oh, that MPS was a show car, i wouldn't be suprised if it didn't actually work lol!
91 Eunos Presso KF-ZE
89 Nissan 300ZX TT 2+2
90 Nissan 300ZX TT 2+0
war_spider
Re: 323 awd -> MX3?
hrhr
yeah but that would be awesome ... MX-3 MPS xD
KL-ZE inside!
Re: 323 awd -> MX3?
Aston Wards wrote:If you're wanting to stay V6, then you may want to look at the Mazda Capella wagon
It did come AWD, but was auto only
Re: 323 awd -> MX3?
Post by Josh »
If you want to stay V6 try the Mazda MPV van, they came AWD with V6, but in ATX only.
the swap requires a fair amount of moding to the rear subframe
Aston Wards
Re: 323 awd -> MX3?
Hmmm, the only MPV's i've seen are the 3.0 V6 :shrug: but maybe the US-spec cars are different?
Without doing any ACTUAL research, i'm pretty sure even the KF Vitara/Proceeds were auto only. Kinda ironic really, Mazda made crappy auto gearboxes and then fitted them to frickn everything! Hmmm, i can't work out why they almost went bankrupt :roll:
