Hi , I own a Precidia Mx-3 i think is GS as it has V6 sign at the rear.
Now , my DRL runs trough head lamps (dont know if its normal) but my LOW BEAMS wont work at all , all i have is DRL and HB , no matter how much i play with the configurations of the control stick. I DO have a cable hanging around under the hood near the AIR filter on the right .. more precise , FRONT-RIGHT corner, it can be that one ??? should i connect it somewhere or my BULBS are not good ... I was thinking about that but then i said: Why when i switch to low beams i get nothing but a very small flash , but the lights stay the same (weak, like DRL) Any suggestions ? thank you.
No low beams
No low beams
'92 Black Mazda Mx-3 - kl-ze
Re: No low beams
possibly just change your bulbs like 40 bucks or less at wal-mart..
1996 mx-3 black 1.8 v6
- umcamara
Re: No low beams
The low beam filaments in your bulbs are burnt out. DRL's use the high beam filaments at a reduced voltage, that's why you have only high beams and DRL's. Replace your headlight bulbs.
Re: No low beams
thx i will try it in the next week maybe.
i have to do a little research to see wich bulbs are the best .
Re: No low beams
Problem inexistent actually , the low beams where working from the begining. I was once in low beam position and i thought they are high beams, but because the light did not show up i was thinking is not good lol , so i always used the high beam position .
ups .![Smile :)](./images/smilies/icon_smile.gif)
ups .
