I bought the 220 cc injectors and rails, and I changed them.
now it is really rich at idle, and stumbles until boost comes on.
should I have left the k8 regulator on? or is the probegt regulator okay?
otherwise, what could my problem be??? I double checked all vacuum lines, and it all seems ok.
at idle, my A/F ratio is 10:1
before the change it was 14.7:1
please help!!!
new injector problem....
- se7en
- XxantwawnxX
Re: new injector problem....
im assuming your still using an FMU? 12:1? You really need a way to control ur fuel usage (standalone) to get the results u want. Maybe switch to the k8 FPR but im not sure if that will do it. Cant hurt to try.
- se7en
okay, I tried the k8 regulator, but still no go.(exactly the same symptoms)
the current symptoms are:
idling rough when cold, and not idling at all when warm.(dies when you let off the gas)
Also has a stumble at about 3500-3800rpms when warm, and at almost all rpms below 4000rpm when cold.
after 4000rpms, the engine really responds well. no problems at all.
what the heck could I have wrecked when I changed my injectors?
could i have knocked off the knock sensor or something? is it in the way of the injectors coming out? everything went together and came apart no problem, no snags or anything.
what the heck. I hate it when my baby is sick
any other ideas XxantwawnxX? anyone else?
7
ps, I know that it should run better than this because k8boosted had this setup before, and he didn't complain of these symptoms.
7
- se7en
I have an idea, what if I put on a adjustable fuel pressure regulator... and turned down the fuel pressure at idle? kinda seems like it is way rich down low without boost, and under boost it is awesome. when running the FMU(I know, I know...) it will bring up the fuel pressure for me. then maybe it will be a good crutch fix until I get my MSnS.
what do you all think?
EDIT: okay, I messed with vacuum lines, and now when it is warm, it runs great except at idle. it won't idle at all. I tried to raise the idle with the screw on the top of the TB, but nothing happens, it doesn't respond at all.
is there another adjustment screw that can raise the idle speed? is something else causing it?
it is at 10:1 at really low idle when it does stay running.
oh yeah, would a Afpr help maybe?
hgallegos915
welcome to the club!!!
my idle af when the computer is in cold mode is at 10 af, also when its warmed up its at 12.. yes 12!
ok to get it leaner.. you need to lower the pressure to like 15 psi or the most lean you can make it.
when you hit boost the fmu will compesante and get you in the right afs.
even 13 af under boost is NOT acceptable. you will detonate even if u cant hear it.
better to run rich than lean. Only way to succesfully control these injectors is megasquirt.
wow im glad u are going the right way, at least now u wont detonate!
-hec
- TREVO123
220 CC on a Boosted engine!! them are tiny!!
hgallegos915
220 cc are not the millenia injectors?
-hec
- se7en
nah, 280cc is millenia s.
220 are probe, and plenty big for my k8.
stays way rich up to 15psi and 7000rpm.
hey hec, how do you hook up your afpr?
thanks
7
thanks
7
