coolant disappearing from fill tank
Posted: December 5th, 2007, 1:30 am
by eyezpinned
no visible leaks, no overheating, no antifreeze in the oil, new waterpump... recently drained and refilled the radiator to remove the air... if it's a leak it's a small one... could it be so small that it burns off/ evaporates before hitting the ground?
Posted: December 5th, 2007, 1:31 am
by tehbrookzorz
You could try getting a pressure test?
Posted: December 5th, 2007, 8:43 pm
by mitmaks
check rubber hose that goes into oil cooler, sometimes its broken and it slowly leaks out most of the coolant
Posted: December 5th, 2007, 9:57 pm
by Mooneggs
or one of your coolant caps is bad and it's evaporating - and that's a cheap easy fix
Posted: December 6th, 2007, 1:44 am
by jason5151
also check over flow hose going into reservoir, it may not be attached!
Posted: December 7th, 2007, 12:21 am
by NorCalMX3
it also can fluctuate if the car is hot or cold (expansion and contraction due to heat and pressure), but i'm sure you know that...
it fooled me once tho...
Posted: December 7th, 2007, 6:59 am
by eyezpinned
lol... i wish all my questions in life got this much feedback. here's an update though: i was actually parked on a hill and observed a small leak... i went back to my garage and sure enough one of my hoses was wet along the back. i examined it, no cracks, but the hose clamp did seem loose, and the hose itself was sitting low on the connection. i took it apart and put it together with everything tight. this would explain why i wasnt seeing a leak: it only presented itself in certain situations i.e. parked on hills. so i'm keeping my fingers crossed. update in a week. thanks for all of your help so far though
