The abs light is on constantly, and the ABS does not appear to work.
I've tried to pull codes by shorting TBS to GND in the usual diagnostics port, is this meant to make the ABS light show codes? Mine just stays on solid. Any thoughts?
club323f guys found me this:
Can't I replicate this using LED and shorting with wire?To access the codes on 1992-98 models, the following are required: Mazda System Selector Switch 49-BO19-9A0 and Self-Diagnosis Checker 49-HO18-9A1 or a scan tool. If a scan tool is used, be sure it is capable of pulling codes from ABS systems. Not all scan tools have this ability.
1.
Connect the Mazda system selector switch and the self-diagnosis checker or a scan tool to the underhood data link connector and to a ground. Set the select switch on the checker to A and the system selector knob to position 3. On scan tools, access the ABS menu. Follow the menu on the scan tool to access the codes. If any codes are present it will display the code number and the corresponding circuit or component.
2.
Turn the ignition switch ONand observe the checker display. Initially, code 88 should appear. If code 88 does not appear check the connections between the checker and the selector. After code 88 appears, watch for and record any other trouble codes.
3.
After the proper repairs are made, the codes must be erased by doing the following:
1.
At the data link connector under the hood, connect the TBS terminal to GND.
2.
Turn the ignition switch to the ON position.
3.
Output all of the memorized trouble codes.
4.
After the first trouble code repeats itself, depress the brake pedal 10 times at intervals of less than 1 second. This will clear all trouble codes.
many thanks,
Marc
