Sunroof adjustment
WhiteFinish
Sunroof adjustment
Post by WhiteFinish »
First of all... Yes I've searched but haven't found an answer. (almost every topic is about leaking or a bad motor)
My problem is:
The sunroof isn't leveled out correctly. When the sunroof is closed one side is higher then the other side.
In my case the drivers side is higher, the point closesed to the front window, (then the rest of the roof) and the passangers side is lower. (also the point closesed tot he front window.
When it rains or has rained there is a little bit of water in the corner at the passangersside of the sunroof.
How can I adjust / level my sunroof??
Thnx
hharb
Post by hharb »
um, i had the same problem, and i pushed it from one side while closing it. i think its a problem with the rails or something, anyways get someone to close it while u push it and make sure its leveled, that was my quickfix
WhiteFinish
I've found something in the manual in page S-54. Is this the correct way to do it?
