kyb struts?
kyb struts?
I need new rear struts but dont want to lower my car at all. Does anyone know if the kyb gr-2 gas struts from cork sport are a good replacement for the oem struts? They are only $77 each so not too expensive.
Thanx
Chris
Thanx
Chris
Thank you I will order them since the canadian dollar is so high right now it shouldn't be to expensive except for the duty maybe. The last shop that I had my struts replaced at just went with used struts that only lasted a year but at the time I needed them and told them it was ok to go with used.
thanx
thanx
- 94mx3precidia
Kyb gr-2 gas struts arnt bad at all. Ive got them in the back and in the front. They take about a week to "break in" and they feel just like stock.
Chertel, How bad are your rear struts? Mine were so bad that if u picked up the center piston and let it go it would just fall really fast and bottom out. Also if u help them upside down and moved the piston up and down liquid would come out lol. I was pretty much driving on my coil springs.
1994 MX-3 GS KLZE, Probinator, Bully stage 1 (probe GT), B&M Short Shifter, 2 1/4" Custom headders back.
- 1992blazeredgs
I have them and I love them... especially for the price. Wouldn't Nopi online be cheaper? I'm not sure about shipping to canada but if you used the dicount code I think those struts are like $48.62 or something random...
why not get them off ebay? 205.xx cdn buy it now for all 4
i believe he doesnt want to lower the car and dont the tokico zx2 struts lower the car 1/4 inch?
- cabriolet
Still its 250 bux for oem replacements
and not gaining anything....whats the discount code btw???
* White 92 MX3 GS * +bone stock K8+ NGK Iridium Plugs + 10.2mm Iridium wires + RAZO shift knob + 8000K HID kit + grant steering wheel [wtb] white fenders
well I had started a nopi discount code thread here:
http://www.mx-3.com/phpBB2/viewtopic.php?t=61728
but I have not gotten an email... by the looks of it maybe you can just change the 3 letter month before the code....
