My first ZE question!!!
- sk8erdude802
Ok so some of you know that I went out and bought Mnemonics SE ZE in atlanta this weekend and most of you dont. this is my first ZE so Im excited. Among some of the problems it has I noticed that sometimes it would idle at 1500 and go up to 2000 and fall back, rise up fall back etc. My k8 did that and I found out it was a vacuum hose I believe. anyway my point it that the ZE does it sometimes but not others and normally ends up falling back to the 1500 or down around 800 so Im not sure if its the same thing or even where to look. The search seams to be acting funny and Im sure there is info on this but I figured Id go ahead and ask. Thanks for the input.
Steve-O
p.s. Could this be caused by the lightweight flywheel he....I have on there?
Steve-O
93' MX-3 GS SE ZE - Sold to Acheron1502! SOLD!!!
93' MX-3 GS SE - R.I.P. K8 with Integra CAI, HEI mod, Koni inserts with H&R's,drift kit, Kicker KX400.1 and KX200.2 amps, 2 kicker 12s, set of 6x9's. Custom trunk enclosure
MyFeedBackThread
![Image](http://api.photoshop.com/home_edc8ea33dca94cb28ff3b581e3c4bdf8/adobe-px-thumbnails/9f2c69c269364749851a91708b58acd2/256.jpg)
^^^^^ Click on image for my work log ^^^^^
MyFeedBackThread
- sk8erdude802
Sounds good. Thanks for the info. Ill check it out.
Steve-O
Steve-O
MyFeedBackThread
MyFeedBackThread
- mx3autozam
I had this issue of random idle for a while... it finally went away after I adjusted the TPS by the book, and set my idle adjustment screw correct.mx3autozam wrote:Or make sure the TPS is adjusted properly.
![Image](http://i806.photobucket.com/albums/yy344/Mooneggz/laguna_seca_signature.jpg)
- WhiteFinish
I had this problem a few years back and found the large black intake hose with the ribs on it had some cracks. When the motor would heat up it woud relax and seal them better than it was cold.
If the TPS or cable didnt solve the problem, I would check your intake system for leaks.
'92 Mazda MX-3 2.5 V6
Work Log http://www.mx-3.com/phpBB2/viewtopic.ph ... 658#438658
I did adjust tps and idle air screw the morning of, making sure it was ready to for you. I never had an issue with it going from 1500 to 2000 and back down before. I can only think a vacuum line has come loose on it.
The only idle issue it ever had was after getting on it, it would idle at 1500 rpms for a few mins then drop back down, sometimes i would just tap the gas slightly and it would drop down. My Kf did this as well and just figured it was just due to getting on it.
Is the idle bouncing up and down or just sticking at 1500k-2k?
it shouldn't be anything serious just an adjustment somewhere.
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
lol appreciate the props to in the garage Cant say I dont miss her, but we're already getting ideas over here for a new toy ![Smile :)](./images/smilies/icon_smile.gif)
Oh and i guess i should of told you the cars Name, since its bad luck to drive a car with no name, not sure how the rules transfer when selling a car but her original name is unfortunetly Sparkles lol i could never get people to call her anything else lol
- sk8erdude802
Thats better than the barney mobile! It was after I was going 80 down the interstate for like and hour and it stayed up there and then fell back after awhile. Nothing major I just wasnted to ask to get some input.
Steve-O
Steve-O
MyFeedBackThread
MyFeedBackThread
- sk8erdude802
Oh its bouncing then after a min it fall to normal position.
Steve-O
Steve-O
MyFeedBackThread
MyFeedBackThread
if you don't feel like adjusting anything just hit your rear defroster switch and it should drop the rpms by about 400
it should even it out nicely too
this was a quick fix I found one day sitting at a red light and it was going crazy LOL - it's like an idle adjustment switch![Very Happy :D](./images/smilies/icon_biggrin.gif)
![Shocked :shock:](./images/smilies/icon_eek.gif)
![Surprised :o](./images/smilies/icon_surprised.gif)
- sk8erdude802
HAHA wow the tings you find out on day to day. Like hitting the dash in just the right place to get that light to come on or something.
Steve-O
Steve-O
MyFeedBackThread
MyFeedBackThread
if its just idling high after running it thats normal, it will drop down, if its bouncing constant like going from 1500 to 800 1500 to 800 1500 to 800 constant thats a problem
