OK so here goes.
I have a ZE but its the newer style one.
I took my K8 ECU into a computer repair shop to get the Probinator chip installed into said K8 ECU.
The guys at the shop ended up wrecking my ECU causing it to no longer start the car period.
A NEW K8 ECU is now being sent to me and a new Probinator Chip as well.
But I have been told that it will be a month at least before I can get the ECU and then I still need the chip installed
So while I am waiting I will need my car. So i have a KL 07 ECU that lets the car run but it seems to have an odd power band, it seems to hesitate until about 5300 rpm then it surges with alot of power up until red line if i take it that high.
Is there a way i can correct this at all or should i just wait it out until, i get all the other things i need??
I HAVE A PROBLEM
- 94mx3precidia
i can get u a k8 ecu easily. There are some barely stripped mx's in the junkyard by my place and they all still have theri ecu's. i will have time this weekend. If you really need one send me a pm or just reply to this message.
1994 MX-3 GS KLZE, Probinator, Bully stage 1 (probe GT), B&M Short Shifter, 2 1/4" Custom headders back.
Ricky_Bobby
- BANNED Member
