engine wiring harness
Bumpysbro
Post by Bumpysbro »
hey guys i was going through my engine harness before i put the motor back together. has anyone bought a new harness straight from the dealer? almost every wire is corroded and having a hell of a time fixing this and thought it would be easier to buy it new from mazda. like any thoughts on the price? its a weekend so i cant call.
Jon
XL200
Post by XL200 »
i tried from the dealer and they couldnt get one so i just went to a wrecking yard and pulled one out myself for $5 and it works fine so far. dealer probably waaayyy more than $5 tho.
Bumpysbro
Post by Bumpysbro »
ya thats what i did and the one i grabbed out of a car was correded up the ying yang haha. ya sucks but ill see what i can figure out. thanks though
95 rs
Post by 95 rs »
i work at a ford dealer and i have seen some harnesses not the engine harness go for up to $1200 cdn. butthats for a 04-07 f150 im gonna probably roughly say $500-$800.
cyclonekid78
Post by cyclonekid78 »
Just go to another Junkyard. It would be loads cheaper then trying to buy 1 new. Might want to call corksport and see if they might have one. I paid 300 for my BPT harness.
93 RS BPTurbo
http://www.cardomain.com/ride/2628805" onclick="window.open(this.href);return false;
umcamara
Post by umcamara »
Jim Gauthier Mazda in Winnipeg wants $1200.00. Incredible waste of money. If you've got time and are good with a soldering iron, you can fix yours up.
'98 BMW 328is M-Tech
Feedback Thread
Bumpysbro
Post by Bumpysbro »
holy crap 1200? no thank you haha. ya im gonna try and fix it myself i just didnt want to waste my time if i could find it cheeper but if not ill go junkyard hunting. man that really sucks thanks guys for your help
shameem
Post by shameem »
You might be better off getting some wire and making your own harness
http://www.painlessperformance.com/webc ... ield=70700
Bumpysbro
Post by Bumpysbro »
thanks for the link awesome stuff. how would you get those connectors on the main ones off the wires? i cant seem to find the locking tabs
lowflyinmx3
Post by lowflyinmx3 »
I did a wire tuck on a celica a year or so back and i had to use a sewing needle for some of the pins in order to get them out. Do a wire tuck while you are at. It looks alot sweeter with seeing nothing but motor.
Mazda.... What happens in the parking lot, stays in the parking lot
shameem
Post by shameem »
Bumpysbro wrote:thanks for the link awesome stuff. how would you get those connectors on the main ones off the wires? i cant seem to find the locking tabs
Every connector might be different - but if you absolutely cannot get the connector separated then you can cut the wire close to the connector - clean up as much as possible and then splice with the new harness.....
I think you can also get new connectors
http://www.mouser.com/search/Refine.asp ... s=P_SField
http://www.suresealconnections.com/
http://www.waytekwire.com/automotive-wire-connector.htm
http://www.sherco-auto.com/wiring.htm
