I need a parts car (body parts) for my 1.6L 93 - however the car I have my eye on is a 94 V6 model. My question is the following: How many parts from the 94 1.8 would be a straight swap over to my 93 1.6? I'm thinking suspension mainly not engine of course. It may come down to the point where my car isn't as good as condition as the 94 but I'm thinking about what the owner mentioned, (it has a front axle (?) problem.) I think she may mean something else here or drive shaft instead of axle.
There is nothing wrong with my suspension or running gear so how much of my parts could fit the V6 is my question. I assume that the CV on the V6 is upgraded or beefier? Brakes: are the V6's bigger etc? Power steering different? etc.
I may just end up using the body panels of the V6 and then part the rest out if the running gear is that much different. The V6 has 250K on it and my 4 banger has half that without ANY issues. Plus the rad leaks on the v6 so with the mileage...
God I hate these choices! (Sound of head hitting table).
Brakes are different. RS uses front wheel discs & rear drums. GS uses 4 wheel discs. GS front calipers are different part number than RS, and GS front rotors are larger than RS.
'98 BMW 328is M-Tech
