2 Questions? First about COP and second about MX-3 ECUs
Posted: September 25th, 2007, 11:49 pm
First of all I am new somewhat according to my info to the left. But actually I deleted my old e-mail long ago and so I am now unable to obtain my login for that name so AKA (KLZE Porsche) Also on P/T!
But to my first question:
Has anybody been successful with a COP conversion? I am working on one myself and I need some tips for a true 6 channel system.
Secondly -I have heard that some people have been successful with using standard 2.5KL ECUs in an MX-3 swap. However I was working with a freind of mine to install a chipped ECU and his car wouldn't run with the chipped KL 2.5L ECU. So I tried chipping his K801 ECU and the car still wouldn't run. I pulled the KLZE EEPROM and installed the original EEPROM and the car runs. So does this mean that the 92-95 MX3 wiring/distributor/ECU are not compatible with KL 2.5L ECUs or EEPROMs or what? I have read that some cars get their CKP (crankshaft postion) signal from the crankshaft sensor and some get it from a sensor in the distributor. If this be true and since the distributor runs at 1/2 the speed of the crank then does this mean that a disty CKP signal will never work with crank CKP wired car? I am looking to make an adapter so that people can use the KL ECUS but I am stuck like a rock in a hard place. I have been breaking my brain studying 4 different wiring manuals and trying to compile all the information. Perhaps someone is much more schooled on this matter and can give me some hints.
