Okay so quick question.
On the one I bought the adapter which is like a back plate sort off gas a nipple on one side which goes to a hose that goes to the actual afpr. But on the other side of the plate its flat as a wall and the stock has a nipple that goes into the fuel rail. Andy said to just buy an o ring and that would do it. Just needed to know how you guys did it or what you used. Thanks.
afpr
- PWRD_BY_HKS
afpr
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
Mine came with 2 different adapters. One like you described, flat on one side and a nipple on the other side. The second one was very similar to the first accept the flat side had a groove for the o ring.
The flat one without the groove will not seal at all.
sorry your kit did not come with the second one.
you will have to improvise.
Andy
Andy
mazdamx3freak
you could always go for the direct fit one by mbx http://www.mbxmotorsports.net/store.htm
- PWRD_BY_HKS
Mine came with the one that has a grove
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
hgallegos915
I used the stock o ring from our stock fuel pressure regulator. works pretty well.
-hec
hgallegos915
Heres the pic you requested.
It came with my afpr so i dont know where he got it.. I know mnewmonic or someone has it posted somewhere.
-hec
