Can you use the original 5spd transmission w/ the BP-T???
I have a 94 DOHC 1.6 i want to get the BP-T... i have read the FAQ and all other sites regarding the swap but i didn't see any info on whether i can use my stock tranny with the BP-T... The engine comes with an AWD trany but would rather keep the same one i have now... it would cut down the cost significantly...
Thanking all in advance
Steve
aka Moe_maX
Steve
aka Moe_maX
- TREVO123
Yes you can use the stock tranny, but you will also have to use the Stock Flywheel and clutch system. Using the stock tranny set up is not recommended as for it is not as strong as a G-series.
- cyclonekid78
^ +1
93 RS BPTurbo
http://www.cardomain.com/ride/2628805" onclick="window.open(this.href);return false;
you could block the tranny off so that it is only fwd, but your loosing power as there are percentages of power to the front and the rear. you dont have to do an awd setup you can just get a protege lx tranny and use it. Sell the gtr tranny
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- TREVO123
Dark_Rider2k3 wrote:Can you use the G-series on the 92 4cyl?TREVO123 wrote:Yes you can use the stock tranny, but you will also have to use the Stock Flywheel and clutch system. Using the stock tranny set up is not recommended as for it is not as strong as a G-series.
Yes you can, You have to change the mount with the protege lx/gt or the EGT mount, You will also have to use the g-series Clutch and flywheel package.
You could block off the Rwd part of the AWD tranny but it would be useless and robb you off power. becuz it will just spinn faster and tend to blow a bearin quicker.
well then.. what tranny is recommended that will keep my car FWD?TREVO123 wrote:Dark_Rider2k3 wrote:Can you use the G-series on the 92 4cyl?TREVO123 wrote:Yes you can use the stock tranny, but you will also have to use the Stock Flywheel and clutch system. Using the stock tranny set up is not recommended as for it is not as strong as a G-series.
- Limegreen mx-3
they have mention many times over before which tranny to use in fwd form mean the g-series trans and all the bs u need to make it work.
read over again..
no what
90-94 mazda protege LX/GT
is a start someone else can fill in for me if they choose too.
read over again..
no what
well when i heard that it is not recommended, i was just wondering if there was an alternative route then the G-series....Limegreen mx-3 wrote:they have mention many times over before which tranny to use in fwd form mean the g-series trans and all the bs u need to make it work.
read over again..
no what
- Limegreen mx-3
i don't see where its says anything about the g-series not recommended
i see about the awd g-series trans being used in a fwd not recommended
where do u see this.. that ur talking about
what i took on what i read is that the stock trans is not recommended with the BP-T and that a g-series should be used... The 90-94 protege lx/gt fits the BP-T and is recomemded... if i read this wrong please let me know...
another question though... will i need new mounts as stated for the 92 4cyl? i have the 1994 1.6 DOHC???
that's exactly what i readMoe_maX wrote:what i took on what i read is that the stock trans is not recommended with the BP-T and that a g-series should be used... The 90-94 protege lx/gt fits the BP-T and is recomemded... if i read this wrong please let me know...
