Is it the syncro?
Posted: September 7th, 2007, 11:49 pm
by Whisper
Had to get my tranny replaced. Long story, don't ask. Got a new "used" tranny, and 3rd gear grinds when going in. All other gears are fine.
Now, I'm not sure how syncros work, but when I double-clutch it goes smooth from 2nd to 3rd, yet when downshifting from 4th to 3rd double-clutching doesn't help - still grinds like a mofo. WTF?
Posted: September 8th, 2007, 1:14 am
by hgallegos915
yah sounds like a syncro.. return the transmission.
Posted: September 8th, 2007, 2:59 am
by Dali
yah it will only get worse, mine started with third, now its all the gears. mostly when down shifting.
Posted: September 8th, 2007, 9:13 am
by jaydog5678
It may or may NOT be the synchros. Either way, the trans needs to be taken apart and inspected for bearing and gear wear.
Posted: September 8th, 2007, 10:26 am
by mx3autozam
Most likely is the synchro....3rd is common on these trannies.
Posted: September 8th, 2007, 12:41 pm
by jaydog5678
mx3autozam wrote:Most likely is the synchro....3rd is common on these trannies.
I'd like to see the 3rd synchro then...
Posted: September 8th, 2007, 2:52 pm
by cyclonekid78
Could be shift linkage, shift rail, shift forks, bad motor mount. Thats the thing about gear clash, it can be a number of things.
Posted: September 8th, 2007, 8:30 pm
by Whisper
If it were any of those, wouldn't that result in all gears shifting bad?
Posted: September 9th, 2007, 1:22 am
by cyclonekid78
The 5 speed tranny has 3 forks and 3 rails. So not necessarily.
Posted: September 9th, 2007, 1:24 am
by Mnemonic
jaydog5678 wrote:mx3autozam wrote:Most likely is the synchro....3rd is common on these trannies.
justin if you would like to play with a gs tranny i have the old one that went out not sure how the internals look
Posted: September 9th, 2007, 11:16 am
by jaydog5678
Thats fine with me B. What was it doing before you took it out?? Was it grinding in 3rd or any other gear??
Posted: September 9th, 2007, 4:38 pm
by Whisper
It seems like the tranny is seeping a bit of oil as well. I'm not a 100% sure, but there's a little drip puddle under what I imagine would be the transmission oil seal. Hmm... Probably not the entire reason it's grinding, but I imagine it's a contributing factor. Could it be?
Posted: September 10th, 2007, 1:13 am
by Nd4SpdSe
You know, I thought I needed a new tranny, my 3rd gear started to grind less than a year after my ZE swap, i thought that maybe the wheelhop from dragging was killing it, eventually 5th started to grind a bit as of this year and 3rd I was double clutching it if i felt like being nice on the tranny. My slave cylinder died on my a few months ago (of course, on a trip back home, thank got i wasn't too far), got it replaced, and you know what, my gears didn't grind anymore...For like 2-3 years I had that probably slowly creaping up on me, thought the tranny was getting worse, in the end, it really was the slave cylinder...I would of gone racing soon after if i didn't screw up 4th when i got stuck when my slave died..oh well, good excuse as any to get my new trans done and in
Although the trans is ready to be put back together and put in the car, I was planning on putting in a new slave (and possible master) when I put in the new trans, guess I don't need to do that anymore.
Posted: September 11th, 2007, 2:49 am
by mx3autozam
I would still put a new master in mike. Its always nice to have everything New!
