manifold does not bolt up help!
- PWRD_BY_HKS
So I'm doing it now but the manifold does not really bolt up. The turbo up pipe is siposed to go under or on top or how does it go through the the rail that supports front motor mount please help !
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
- PWRD_BY_HKS
Do you by any chance have a picture.
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
- XxantwawnxX
My modded next to my unmodded.
And here are some other peoples designs
Last edited by XxantwawnxX on August 31st, 2007, 5:04 pm, edited 3 times in total.
- XxantwawnxX
<3fieromx3 wrote:LOL i was just posting the link up to ur thread ant
- PWRD_BY_HKS
What about for the down pipe is that gonna get in the way or what
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
- PWRD_BY_HKS
Or does it also go under the cross member
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
- XxantwawnxX
u can see how the down pipe runs in the last pic.
- PWRD_BY_HKS
Is the down pipe supposed to sit really close to the distribuitor. Can you guys show me some pics on how you did your intercooler piping I'm having a hard time figuring out how to get back to the TB. Thanks
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
hgallegos915
ya should bea really close if U dont mod the pipes. They have some stuff you can use to coat the disty to protect it from heat. Check out the turbo probes on probetalk. And the red turbo mx3 here.
-hec
- XxantwawnxX
This is how close my pipe is to the disty. Never even came close to melting.PWRD_BY_HKS wrote:Is the down pipe supposed to sit really close to the distribuitor. Can you guys show me some pics on how you did your intercooler piping I'm having a hard time figuring out how to get back to the TB. Thanks
And using all 3 pics u can kinda see how i ran my inter cooler.
This is how i ran it when i had the old intercooler.
And this is the NEW intercooler but it pretty much run the same way..just hacked the pipes shorter.
- ScooterBovine
