Clear Lenses
s1zzl3
Clear Lenses
Post by s1zzl3 »
modified my stock headlights a bit
check em out
:D
new fenders and hood and pearl white paint on the way
s1zzl3 & s1 Designs 2009
http://www.cardomain.com/ride/2312320
94mx3precidia
Post by 94mx3precidia »
are those just new OEM lenses or did u get aftermarket ones? id like to fix mine up.
1994 MX-3 GS KLZE, Probinator, Bully stage 1 (probe GT), B&M Short Shifter, 2 1/4" Custom headders back.
s1zzl3
Post by s1zzl3 »
theyre oem
but they have no dispersion pattern.. jus a clear lense
i removed them and painted the inside white to match the white paint job soon to come
atlantamx3
Post by atlantamx3 »
hahahaha
good luck actually seeing anything.
with no dispersion pattern, they will be worse than the stock headlights.
:roll:
~Perry
Please visit
http://www.mx3-atlanta.com
ScooterBovine
Post by ScooterBovine »
I may be wrong, but don't our lights work like a flashlight? A bulb shines into a surrounding "chromish" material which then reflects that light forward? So, painting that "chromish" material would render it completely null and inoperable?
No more MX-3.
s1zzl3
Post by s1zzl3 »
atlantamx3 wrote:hahahaha
:roll:
i was asking about this on another thread i made
and i was curious
maybe it wont work at all but maybe it wont make much of a difference... well c
ill update u guys, i still have my stock headlights
so i was thinking of comparing one with dispersion pattern and one without c how much a difference it would actually make
im not driving my car around
its in the garage getting prepped for paint so i can pull it out and test it
i guess i was jus curious :D
Urbanconcept
Post by Urbanconcept »
If it doesn't work I will buy those lenses from you. I'm working on a projector project and not having to sand down the fluted lense would save me a lot of time!
Friendship is like pissing your pants: Everyone can see it, but only you can feel its true warmth.
s1zzl3
Post by s1zzl3 »
ScooterBovine wrote:I may be wrong, but don't our lights work like a flashlight? A bulb shines into a surrounding "chromish" material which then reflects that light forward? So, painting that "chromish" material would render it completely null and inoperable?
your headlights work like this: the light is reflected by the concaved chrome reflector in the back.
the light bounces off and on to the dispersion pattern which disperses the light
throughout the lens by collecting on the ridges...
instead of passing by like it would with a clear lens.
notice how there are more ridges near the chrome part thats closer to the lens
thats because the source light is not able to reflect there normally for obvious reasons so they use a dispersion pattern to collect the light in that area (the light collects on the ridges then bounces back on to the chrome part and back and fourth) giving the impression that light is been emitted from that part of the lens
as well
sooo since no source light is being reflected from that area it is really not that important i can get rid of it by painting it over, so i can expect no light to be "emitted" from that area whatsoever.
Hoodzy
Post by Hoodzy »
hard to tell from the pics but u left the little nubs on?? why wouldnt u just sand those off?
and i'm really curious to see if they are gonna work my guess not so much.. the stock headlights are crap enough as it is those are gonna be weak:P
1995 Creek Mica Blue GS
s1zzl3
Post by s1zzl3 »
Hoodzy wrote:hard to tell from the pics but u left the little nubs on?? why wouldnt u just sand those off?
i dunno i just didnt notice them
but really the light should be same to brighter but just not as focused
they use the ridges to reflect straying light away from traffic and toward certain zones beside the vehicle but the main light is still going to be reflected in front on the vehicle because of the concaved reflector.
Return to “Appearance”
