MegaSquirt...Newbie
Posted: August 11th, 2007, 7:57 pm
by ModMX3 - (Carmaster2005)
Just wandering how many people have Megasquirt installed on their mx ? How Hard was the installation ? And how hard was the tune ? anyone running spark also. I want to set up a full standalone and im sure i could figure out how to install it but looking at some of the sample tuning charts and what not, they have me lost. pretty advanced stuff. Also is their anyway to preload base charts from the stock computer or maybe a miata and then adjuest from that ? Any input about megasquirt would be awsome !
Posted: August 12th, 2007, 1:38 pm
Anyone Have any input on this ? I have ran a few searches but Most of the information is slim on megasquirt and the mx.
Posted: August 12th, 2007, 1:45 pm
by shameem
I looked into megasquirt as well as DIS a while ago - the setup seemed relatively straightforward and i was told that megasquirt comes with a "autotune" function that can create a decent base map after a few minutes of driving around.
But if you are turbo'd - you can try your luck with autotune or you might try some local tuners in your area - also probably miata forums might help... There is a megasquirt faq on the engine electronics section which covers a lot.
Posted: December 22nd, 2007, 10:17 am
by ScooterBovine
I wanted to get a crappy laptop strictly for MegaSquirt tuning. I would use my Alienware laptop, but the screen is not working. Anyways, my question is:
What should my specs be? I'm sure a 486 laptop won't cut it, right? Haha!
EDIT: I could use my Wife's Laptop, but it doesn't have a serial port on it. Would the USB to Serial cables work? Or does it have to be Serial to Serial?
Re: MegaSquirt...Newbie
Posted: January 12th, 2008, 2:06 pm
by EZ_4_FUN
486??? that is old. Id say go with a Pentium 2; they are cheap and easy to find. I actually have an old P2 labtop if your interested (Toronto). The battery does not work, so it needs to be plugged in. (offers?)
I'm running MSnS 2.2 fuel and spark.
My only problem at this time is getting the IAT(intake air temp.) and CLT (coolant) sensors calibrated properly. I have no issues in the summer, but come cold temperastures and the readings in Megatune go to -40F (impossible).
Advice: Read the manuals over and over. You will be surprised to find something new each time through it!!! Start off with fuel only setup. Make sure you can get it started. Then move onto spark if desired. Give yourself time, don't rush it.
Re:
Posted: January 12th, 2008, 2:08 pm
by EZ_4_FUN
ScooterBovine wrote:EDIT: I could use my Wife's Laptop, but it doesn't have a serial port on it. Would the USB to Serial cables work? Or does it have to be Serial to Serial?
I'd be surprised if the labtop did not have a serial port... Are you certain?
Don't bother with USB-Serial, bad choice. The connection for whatever reason doesn't work in every instance. Serial-Serial without a doubt is the BEST/only choice.
