2 cylinders with no compression...
reegler
Post by reegler »
So i took my car in today to get it looked at because everytime i would press on my break my rpms would drop and my car would almost stall. Anywho, they told me that two of my cylinders have no compression and that would cost $1000 US to fix it but even they couldnt assure me they wouldnt start leaking oil eventually. So is it worth fixing or just getting a new engine. I havent read very much about swaps but what i have right now is a 4 cyc 1.6L sohc and i wouldnt mind getting a dohc but i would want a fairly easy swap.
much love
tim
95 rs
Post by 95 rs »
look up the bp swap.... apparently its the easiest swap to do for the sohc and it has alot of potential....
reegler
Post by reegler »
any idea where to find a BP engine... Do people usually get them from junked cars?
Skuce
Post by Skuce »
reegler wrote:any idea where to find a BP engine... Do people usually get them from junked cars?
Yup. Escort GT's and Protege LX's (or GT's in Canada)
There is lots of info on the board on how to do the swap. And it's a very nice engine. Especially if you get the G series trans with it (just say no to F series)
Drew
'95 EGT 1.8
T
'93 ELX 1.9 SC
'91 ELX 1.9
reegler
Post by reegler »
Will my current tranny swap?
