K8 ECU Question
K8 ECU Question
Hey guys I have a question about the K8 ECU. I have the klze installed and I wanted to get a probinator chip for my ECU but it turn out that mine can not be chiped, its an early 1992. Well I found a junkyard 2 hours away that has an ecu from a 1993, however I will not be able to crack it open to see the eprom number before I buy it. What are the chances that it will be the one that can be chipped? I don't really want to waste my money.
- Tunes67
Well I am not an expert on this topic.. but everything I have read says the 93 will be just fine to get chipped. How much does the junkyard want for the ECU? Have you tried e-mailing the Probinator guy and asking him about it? Cheers
Tunes67
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ![Wink ;)](./images/smilies/icon_wink.gif)
- 1992blazeredgs
- 1992blazeredgs
- Tunes67
You have to open the box up to get the eprom number. Its not on the outside of the ECU.
Tunes67
Tunes67
- 1992blazeredgs
- PATDIESEL
There will be a number printed on the back of the large computer chip looking thing. That is the E-prom and the number he needs.
- 1992blazeredgs
- 1992blazeredgs
Of the three chips i think to be the eprom but am not sure. I have
079753-1654, mp7990 1m30 this chip had a symbol that looks like either I/D or Half of a capital N leading into a capital D, and 2a1 rj hd63b21p this one is stamped japan underneath the number.
I also read up on the probinator chip and it says 93 and up ecu's, but i dont know why a 92 mx3 gs ecu would be any different than a 93.
Nate
Nate
Looking for another Red GS.
- 1992blazeredgs
No problem, just trying to help, and i learned in the process always good. If it were me, i would call the the people who make the probinator chip and find out why the 92 wont work. My guess why it lists 93-95 ecu because the probe had the kl in it from 93-97 and obdII started in 96. Most probe guys dont realize the mx3 had the exact same technology in the k8 in our cars a year earlier in 92.
Nate
Nate
I had a 93 MX3 ECU and Probinator couldn't change the timing and fuel maps on mine. It ended up all he could do with mine was change the VRIS points, but I had to keep the fuel and timing exactly the same as the K8 chip. If you want Probinator to give you a KL31 rechip, I'd suggest buying a used 93-94 Probe/MX6/626 V6 ECU.
