oil in spark plugs
Posted: July 12th, 2007, 12:28 pm
by fritzfab
hey guys i went to change my spark plugs and wires and when i removed the back ones 2 out of the 3 had oil all over them what does that mean, i know its not good but what causes that does anyone know?
Posted: July 12th, 2007, 1:22 pm
by IRISHmx-3
leaking gasket or that the rocker cover is loose and oil is escaping!
could also be from someon sprayine eg. WD-40 onto the plugs!
I did it once when my plugs got wet so people to do it like!
Posted: July 12th, 2007, 2:08 pm
by V6Gav
was the oil on top of the plugs or actually on the electrode itselv?
on top isn't a problem, just the rocker gasket needs replacing which u can leave if u want, shouldnt loose that much oil and its not really a bad problem.
Posted: July 12th, 2007, 2:34 pm
by fritzfab
no the oil was all over the spark plugs they were covered from top to bottom and dripping when i pulled them out , and it could possibly be a really bad leak and my car definately lost power from it i can tell so im really concerned what do you suggest
Posted: July 12th, 2007, 8:17 pm
by mitmaks
fritzfab wrote:no the oil was all over the spark plugs they were covered from top to bottom and dripping when i pulled them out , and it could possibly be a really bad leak and my car definately lost power from it i can tell so im really concerned what do you suggest
Im sure when you removed your spark plugs oil that was on top of them just poured down and coated rest of the spark plug. You just need to replace gasket.
Posted: July 13th, 2007, 4:26 am
by V6Gav
If you run it for a while the oil should burn off and the engine should be fine, shouldnt be any loss of power with a leaky rocker gasket. If the leaks that bad then id replace the rocker gasket, the front of mine needs replacing and its and easy job, think the back will be a bit harder but shouldn't be a big job.
