First off there are three yellow plugs that plug into the B6 ecu, and only two yellow plugs on the EGT BP ecu... what's the 3rd plug for?
Also there are some plugs that don't connect to the ecu that look the same but the pins are in different positions, do I change them around and to what?
How can I tell if it's OBDI or II?... I believe it's I, maybe?
Which harness do I use and how do I make it work?
Thanks!
![Image](http://members.shaw.ca/jonathan.hung/Car/BP/HPIM1509.jpg)
