My ze Parts list, What did I forget
Posted: June 24th, 2007, 6:58 pm
Well I got my ze. It looks good. Now I will be doing the swap this winter so it gives me some time to get some parts together and get the motor work done. Here is what I am thinking about getting. I have done some research but could always use some input.
Probinator Chiped ecu
Ground Wire Set
Interprep valve springs
Mystique 2.5L valve seals
stock klde valves (intake and exhaust)
stock klde retainers
klde exhaust hla's
Clutchmaster Stage II R or III and Flywheel (Undicided)
SS Clutchlines
urethane Filled mounts
Gasket set 2.5l Millenia
Timing Belt
Oil Pump
Wires
Plugs
I Have the the headers and CIA already.
Not sure If I need these but I was thinking about getting them.
Water Pump???
New Starter (Mine is on the way out)
Rings??? I have compression between 190-200 in 1,2,4,6
The compression for 3,5 was 180,183 I was thinking on getten new rings put in while I had the motor apart.. Any Input?
Is there anything else I am missing or something someone would recommend.
Ground Wire Set
klde exhaust hla's
SS Clutchlines
Timing Belt
Oil Pump
Wires
Plugs
Water Pump???
