URGENT need help
URGENT need help
didnt know where to put this but installing a new deck and need to take out the old aftermarket deck and i was wondering how to get it out? thanks
- PATDIESEL
Read the directions in the online manual. It is located on the main page on the left side under technical.
http://www.mx-3.com/tech/audsys/
:) On the main page under "MX-3 Tech Info"
After market stereo is easier,
Take off the trim around the deck with a flat head screw driver
Pull out the deck with your figures, sometimes they have the clips on the sides so find something thin enough to go between the deck and the cage and it should come straight out with some wiggling.
Disconnect the wires behind the CD player and it should come out....
Installing a new deck is pretty much in reverse but rewiring your new deck...(depends on if it has the plugs or if someone cut them off) if they cut them off, well then cut the wires from your old cd players wire and wire your new cd player's wires exactly the same way.
1993 Mazda MX-3 GS, V6 KLZE 2.5L, CenterForce Duel Friction Clutch, Nylon Shifter Bushings (from Imazda.com), Integra Cold Air Intake, Millenia Intake Manifold, Indigo Gauges, Pacesetter Header->Resonator->2.5" piping->Dynomax Muffler, VSX Front and back bumpers from FX Designs, AWR Front and back Motor Mounts.
