Quick fuel injector question
Posted: June 18th, 2007, 11:18 am
by 1992blazeredgs
I was hoping to get my injectors tested/cleaned before i slap them on my new motor. But the cheapest i could find was $26 bucks per injector. So my question, should i skip that step and hope they are fine? They came used on the intake manifold i bought and have no idea how well they work.
Nate
Re: Quick fuel injector question
Posted: June 18th, 2007, 12:23 pm
by babyblueMX3
1992blazeredgs wrote:I was hoping to get my injectors tested/cleaned before i slap them on my new motor. But the cheapest i could find was $26 bucks per injector. So my question, should i skip that step and hope they are fine? They came used on the intake manifold i bought and have no idea how well they work.
Nate
This is a typical price for injectors testing.
Seriously, I've seen so few of them fail, I would go ahead and use them.
But that's just my opinion, do whatever you want.
Posted: June 18th, 2007, 12:49 pm
by 1992blazeredgs
I have found alot cheaper, from places that will do it with the injectors in the car. I think i will reuse them without testing, and if i have any problems have them tested once the motor is in the car.
Nate
Posted: June 18th, 2007, 12:57 pm
by Mooneggs
I would say try them out... you will definately know if they are not performing correctly. They are relatively easy to take out once the motor is in the car... just a little tedious...
