16" Konig Britelites on my MX-3!
- tehbrookzorz
Finally got them yesterday.
They are Konig Britelite super lightweight alloy rims in 16" x 7" (offset 40mm). According to Konig they weigh 15.3 lb each, which from what I can tell seems quite valid.
Too bad the tires I got at an awesome deal are too tall to fit properly. I don't suggest P205/55R16 on the rims listed above in conjunction with the ZX-2 struts. They WILL rub the strut. I had to use wheel spacers to push them away from the struts in the front, which isn't great. Guess I'll go smaller when these wear out.
Cody
good choice perry has the same wheels on his mx3
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- tehbrookzorz
- mx3autozam
- tehbrookzorz
Well, with the strut mount pointed at its most positive setting, not using camber bolts in the front, they definitely rub against the two reinforcing bars under the lip of the bottom spring seat on the strut. I might try turning the strut mount more negative and adding camber bolts. These are pretty wide footprint tires though.
Cody
- atlantamx3
The Konigs look great on you car! What rims did you have before, did your handling improve?
Since a few days I have 16" on my MX-3 as well. (Royal gunmetal 16"x7J Rota Slipstream) They have offset 45 and they don't rub with 205/45/16 tires (Dunlop SP Sportmaxx).
Accelleration/steering/braking have improved greatly over the 18" Bellini's! The 18's where about 23lbs, the Rota's only 14lbs.
1995 noble green MX-3 RS (sold)
1994 clear white MX-3 GS (r.i.p.)
1987 white RX-7 FC
1993 mighty grey MX-3 GS
1987 white RX-7 FC
- atlantamx3
- tehbrookzorz
Yep i got a set of them, love the looks of them, but atlantamx3 is right, you should have gone with 205 45's
little less tire. looks better imo.
- Bochek
- Bochek
- tehbrookzorz
