Page 1 of 3
ProjectMX - BP swap and AWD Swap
Posted: June 12th, 2007, 10:49 am
by projectmx
Well I realized I never did a worklog for my new mx soooo here we go :) let me know what you all think
working on the block
mmm tasty wiseco 10.2:1 pistons
Putting things together
This is how an oil pan should look
Cylinder head with 1mm oversized SS valves
P&P and port match
almost done!
This is where it's going!
Posted: June 12th, 2007, 10:52 am
by projectmx
Keeping the engine cool! just a mockup it will fit much better when we are done
Trunk minus the wheel well... I plan on adding a depression for the fuel cell back here and a spot for the battery also.
You should also be able to notice the spots I added a little to support the body where the bolts go through to hold on the AWD rear subframe
Posted: June 12th, 2007, 3:38 pm
by PATDIESEL
Good clean work, and I don't give that prop often. Good luck on the project, it looks like it will be well done. As for the radiator though, that looks problematic. It seems to be too tall. I wouldn't want mine to hang down under the car and be the first thing that gets hit when I go over something too high.
Posted: June 12th, 2007, 4:11 pm
by projectmx
The only part that really goes bellow the support are the mounting pins that stick down the rest is actually flush with the bottom of the support... although I do plan on eventually making a piece that goes under the radiator for better protection
Re: ProjectMX - BP swap and AWD Swap
Posted: January 25th, 2008, 12:34 am
by gr8
Dam thats clean. Some times i wish i went with a BP and not a Ze. You live in IL right i think u sent me a message on cardomain back in 2004 LOL i havent been on that site in ages. I think u have a white RS at least the name is the same.
Posted: January 25th, 2008, 7:41 am
by projectmx
actually i moved in october to detroit. the car is still in the chicagoland area cause it still needs a decent amount of work, i was in the hospital a bunch and some other stuff got in the way of me getting the car done.
Posted: January 27th, 2008, 3:37 pm
by Limegreen mx-3
Nicely done
i thought i was crazy
but u take the cake
loving that BP
Posted: January 28th, 2008, 11:24 am
by projectmx
thanks man, and yeah i'm crazy
Posted: January 28th, 2008, 6:35 pm
by Limegreen mx-3
that makes 2 crazy mazda people
if only there where more of us
there be a hell of alot more faster MX-3's in the streets..
Posted: January 29th, 2008, 9:37 pm
by gr8
Hey im crazy 2 well your more crazy LOL. Kinda suck u dont live around i saw a pic on ur cardomain page of u autoX at TireRack plant. I never been looks like lot of fun. Im gona try to find one closer to chicago and go spectate see how it looks.
Posted: March 31st, 2008, 11:27 am
by projectmx
So we got a ton done last weekend! most importantly I figured out why the engine wouldn't fit in and fixed it, now it fits perfectly in the engine bay. Here is a link to most of the pics from the weekend more will be up later today:
http://projectmx.net/workdays.aspx
And here are a few pics:
Image Image
Posted: April 6th, 2008, 9:10 pm
by Nd4SpdSe
What was the reason behind modifying the front subframe?
Posted: April 7th, 2008, 9:34 am
by projectmx
the AWD trans is way bigger so you need to make space. or you could try and find an AWD front subframe
Posted: April 7th, 2008, 10:20 am
by solo_ryder
Nice build so far! Any ETA?
Posted: April 7th, 2008, 10:30 am
by projectmx
hoping by end of june we'll see though
