Page 1 of 3
i know this is getting old but please help
Posted: June 6th, 2007, 9:49 pm
by xboxlivemonkey
hey whats up , lately iv been reading alot in the forums here
my cars rpms will go up and down when i accelerate
and my car would stop accelerating when i do a turn it would stop and then try to go
any way here are a few pics and i want to know what they are
also what can i do i was driving and my car shut off ( wouldent turn on after ), i gave it a boost and it turned on took it to discount , the meter said it was good ...... any way , theres a hose htat connects to the manifold and a stick ion the cap and rotor that is leaking oil or something
here are pic (sorry for saying that twice )
also there is a clicking noise in the cap and rotor
what is that
the hose that connects to the pic above not connected to anything , what does it connect to ??
its leaking oil , why ?
( took this driving againts my friends mustang you cant see him lol )
<a><img></a>
we tighted that to see if would help the erratic rpm
thanks in advance
Posted: June 7th, 2007, 12:35 am
by mazdamx3sohc
1. what disconnected hose? open the pic in paint program and circle it.
2. dont post illegal racing pics..you'll get reamed out.
3...i feel sorry for that poor mx-3.
Posted: June 7th, 2007, 12:43 am
by xboxlivemonkey
[quote="mazdamx3sohc"]1. what disconnected hose? open the pic in paint program and circle it.
3...i feel sorry for that poor mx-3.[/quote]
sorry its not a racing pic , actually its me takling a pic since he was behind me in traffic
http://i41.photobucket.com/albums/e294/ ... nected.jpg
it looks connected i held it at a wrong angle sorrt
Posted: June 7th, 2007, 12:47 am
by mazdamx3sohc
hmmmm got any clue where the other end is connected? it could possibly (doubt it tho) be the piece that connects to the intake hose. if that gets disconnected your car will run very very rough but most likely it wont run at all, or itll stall every 2 seconds.
Posted: June 7th, 2007, 12:51 am
by xboxlivemonkey
[quote="mazdamx3sohc"]hmmmm got any clue where the other end is connected? it could possibly (doubt it tho) be the piece that connects to the intake hose. if that gets disconnected your car will run very very rough but most likely it wont run at all, or itll stall every 2 seconds.[/quote]
i mentioned (i think ) it connects to the manifold
http://i41.photobucket.com/albums/e294/ ... 060142.jpg
Posted: June 7th, 2007, 12:57 am
by 93_MX3 GS
as for the hose it goes to the intake box rite there in red , it appears to be busted off, tha plastic piece is still in the hose no? and for your leak you need to replace the rubber o-ring in there ,just unbolt the dizzy n pull it out. unless your valve cover leaks. but try reconnecting that hose n check your idle.
Posted: June 7th, 2007, 12:59 am
by xboxlivemonkey
[quote="93_MX3 GS"]as for the hose it goes to the intake box rite there in red , it appears to be busted off, tha plastic piece is still in the hose no? and for your leak you need to replace the rubber o-ring in there ,just unbolt the dizzy n pull it out. unless your valve cover leaks. but try reconnecting that hose n check your idle.
[img]
http://img245.imageshack.us/img245/4199 ... tedxz9.jpg[/img][/quote]
i tried it but my car wouldnt work for s--- , it got as bad that it would not turn on , my brakes would not work for some reason and my motor would run louder but not efficient
Posted: June 7th, 2007, 2:22 am
by mazdamx3sohc
1....if your leaking around the valve cover gasket and the distt mounting gasket, the c gasket is 15 bucks, do not tighten much when replacing, and the disty mounting gasket is 1.99.....easy as hell to install and fix..
NOW AS FOR THE REASON YOUR CAR IS EFFED UP....
your spark plug wires arent installed in the correct spots on your distributor, check out a pitcure of wich plug wire goes where, that will fix your problem...
Posted: June 7th, 2007, 5:38 am
by zCat
Sounds pretty right on. A lot of people think that problems like these are linked to weird crap, but it has usually been in my experience an issue with something in between the distributor and the engine itself; I.E. cap, rotor, plug wires, plugs.
Posted: June 7th, 2007, 11:46 am
by xboxlivemonkey
[quote="mazdamx3sohc"]1....if your leaking around the valve cover gasket and the distt mounting gasket, the c gasket is 15 bucks, do not tighten much when replacing, and the disty mounting gasket is 1.99.....easy as hell to install and fix..
your spark plug wires arent installed in the correct spots on your distributor, check out a pitcure of wich plug wire goes where, that will fix your problem...[/quote]
how did you figure that out lol , how do i know which one goes where
Posted: June 7th, 2007, 12:18 pm
by mazdamx3sohc
i am a geneous....also, you have to find a picture of a motor like yours, and find out the "firing order" wich plug wire goes where on the cap, and on the head.
Posted: June 7th, 2007, 2:44 pm
by xboxlivemonkey
[quote="mazdamx3sohc"]i am a geneous....also, you have to find a picture of a motor like yours, and find out the "firing order" wich plug wire goes where on the cap, and on the head.[/quote]
i cant find a pic any where , and the rpm only drops when i turn a corner
also there is a hissing noise
and where does the losse hose go to
Posted: June 7th, 2007, 7:19 pm
by mazdamx3sohc
it goes to that hole on your air intake box im guess, try it...and there is a post under the pics and immages sessions where people post pics of motors in the "show pics of your engine bays" one, look around for it. maybe someone else might know it.
Posted: June 7th, 2007, 7:30 pm
by xboxlivemonkey
[quote="mazdamx3sohc"]it goes to that hole on your air intake box im guess, try it...and there is a post under the pics and immages sessions where people post pics of motors in the "show pics of your engine bays" one, look around for it. maybe someone else might know it.[/quote]
it doesnt fit there = (
Posted: June 7th, 2007, 7:33 pm
by mazdamx3sohc
check for another open hose along your firewall or something, idk man, if you can get a better picture let me know, like an up close of the hose so we can see what it looks like and maybe where the other end connects to.
