symptoms of failing water pump.
Posted: June 6th, 2007, 1:52 pm
by 94mx3precidia
hey, im looking for symptoms of a failing water pump? Just in case down the road my waterpump ends up failing i'd want to know. I know that the temp guage will obviously go up, but what are symptoms?
Posted: June 6th, 2007, 3:28 pm
by PATDIESEL
They ususally leak before they fail. It is a gear driven mechanical part running off the power of the belt so mechanical failure is not likely. You could have corrosion of the blades, but that is unlikely if you use mineral water and coolant like you should. Tap water will rust the pump and the aluminum inside the motor. Symptoms would be overheating.
Posted: June 6th, 2007, 5:07 pm
by Tunes67
Slow heater warm up. If the impellor of the water pump gets chewed up or corrodes off.. it can take longer for the heated coolant to reach the heater core. Most noticable on cold days of course. However.. its been shown that even a pump with the impellor worn down badly will still move the coolant in the 4cyl engines. Dunno if it would in the V6 or not, but I doubt it would since there is more coolant in the system. If it did.. it would take even longer for the heater to start blowing warm air.
Tunes67
Posted: June 6th, 2007, 9:02 pm
by 94mx3precidia
thanks for the tips guys. btw, what is the normal temperature for a v6 msx saposed to run at? Mine is a little over half and im not sure if thats too hot or not.
Posted: June 7th, 2007, 12:40 am
by PATDIESEL
Depends on the thermostat. I think stock is a 180* thermo. Meaning that it should run at about 180 degrees, but will fluctuate above and below that by 10-15 degrees or so when running properly.
Posted: June 7th, 2007, 11:50 am
by 94mx3precidia
what do you mean 180*? 180 degrees is either north or south, ie up or down.
Posted: June 7th, 2007, 12:57 pm
by Tunes67
He means 180 degrees Farenheit.
Tunes67
Posted: June 7th, 2007, 3:23 pm
by 94mx3precidia
gotvha, my bad. lol
thaught u meant the direction of the needle.
