I swear I'm going to rip my hair out over this!
Posted: June 2nd, 2007, 6:20 pm
Hey! Okay, list of what's happened to date.... lol
changed valve cover gaskets, removed egr in the process(well...really just cut the egr pipe off the manifold and closed off both ends)
Car runs fine for about 3 weeks
Car stalls one day out of the blue, I check my oil(oil changed a month ago) and I have maybe a liter in there, so I add more oil.
Start driving, car stalls again, just shuts off, no sputter, nothing.
Alternator and Battery are fine.
Wires are fine, checked just one plug but it seemed fine and I really dont think that is the problem as I am getting no spark anyways.
Checked all my connections in the engine, everything seems fine other than a wire thats been loose awhile and never seemed to be a problem.
Replaced ignition coil and fuel filter, start car, it idles rough(loping really..)
Drive car to work, doesnt die, but is still loping really bad, car dies the minute I pull into the shop at work.
Did the HEI mod (without the blaster coil though as I have just replaced the ignition coil)
Car starts fine, runs for over half an hour without dying and idles peeerfect but when I rev or drive it, it bucks and kicks and when I let off the accelerator I hear popping noises. Dies in Reverse and on the way back to the shop dies if i let off the accelerator.
Pulled disty apart, checked everything with a mechanic from the shop, it looks fine,adjusted the timing (over the very short period of time the car would run)
Got that finished and the car starts dying again, this time it won't start at all, checked for spark and there is none. checked for voltage to all the plugs going to the disty and they're fine, pulled disty apart again, put it back together, still wont fire up, it turns over and cranks and everything comes on but the engine wont fire up!!
Fuel pump is getting 12V as well, I checked the plug going to it, and as far as I my knowledge extends, I am getting air, so I have fuel, and air, I just have no spark! AAAARRRRRGGHHHH!!!!!
Could it by chance be my ECU? Or maybe I should try a new disty? Or maybe I should try the Blaster coil as well?
This is getting frustrating, I havnt had a vehicle in 2 weeks now and my work hours are all over the chart and work is out of town so I need to fix this asap!!!
Any suggestions are extremely appreciated!
