Lowwww compression but timing belt still on track?
A while ago my car's CV joint wrecked so I bought a new one after a few weeks, put it all in, and now as of about 2 weeks ago my car wont start up again. We checked for bad gas, a whole list of things, then we tried a compression test, I think the standard pressure was something around 185 lbs in the repair manual, my car averaged about 50 lbs of pressure. So we thought the timing belt was out, popped everything off, and it was all in place. The only logical explanation in my mind is a blown head gasket, but the car was running fine before it broke, nothing the matter with it other than the CJ joint. I started it about a week after the CV joint broke, it was boggy as hell, just ran like crap, and now yeah, it wont start. Help please? =)
- Tunes67
Just cause your timing belt is still in place doesnt mean that it hasnt jumped a tooth or two. Its also possible that the timing belt hydraulic tensioner went bad.. unless you really checked the belt well.. I'd go back and take another look at it. Also.. if your averaging 50 PSI on all 6 cylinders.. well.. I might consider 1 blown head gasket.. but blowing both head gaskets in the same manner on both sides of the engine at the same time? Eh.. If that happened.. buy a lotto ticket tomorrow cause thats some damn LONG odds right there. Your timing belt is still your most likely culprit.
Tunes67
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ![Wink ;)](./images/smilies/icon_wink.gif)
