MOT FAIL - Emissions
Posted: May 22nd, 2007, 4:40 am
by Reborn
Just had about £900 work done on my car to get her back on the road again after taking it of for 6months.
Suspension, Braked, Oil/Fuel filters, New Clutch (MX-6) and other things.
But its failed the MOT on its emissions, 2nd Fast Idle, I have a Custom exhaust which isn't especially mad, its just a twin 3.5"
I'm concerned i have a dodgy 02 sensor or perhaps something worse....has anyone got any experience in getting a car through its MOT with this kind of problem
Posted: May 22nd, 2007, 9:41 am
by MX3ak
V6, right?
If the problem is Idle, you can adjust to specification (650rpm) by puting in diag mode plus adjust screw on throtel body.
If the problem is variable idle (up, down) the you got a leack in vaccum system. Check every air hose aroud intake manifold.
If the problem is emissions, check catalytic converter.
But maybe to much oil burning too. then only solution is new head gaskets or/and valve steams.
Best luck!
Posted: May 23rd, 2007, 3:29 am
by Reborn
Not that, apparently its needing two new Lambda sensors also known as 0xygen Sensors for the exhaust..........that explains why she's been running rich recently.
So thats £153 per sensor...ouch!
Posted: May 23rd, 2007, 6:28 am
by capamx3
Are you sure that the sensors are bad, not only just an error in the diagnostic box?
Posted: May 23rd, 2007, 6:42 am
by Reborn
The garage is pretty sure its the sensors yeah.....
Sounds about right its had all the symptons, hesitation under acceleration etc.
Posted: May 23rd, 2007, 7:00 am
by MX3ak
If it´s the Lambdas error on the Diag, then yeah, better replace those. Then reset ECU.
You can get them both for less than 50$ on ebay. Universal Mazda 4 wires.
Posted: May 23rd, 2007, 7:58 am
by Reborn
Thanks for the assistance!!!
