Valves
Posted: May 18th, 2007, 8:50 am
by MX3ak
Need to know, what kind of metal are made the valves of K series, thanks!
Posted: May 18th, 2007, 9:02 pm
by PATDIESEL
Some sort of steel alloy I would think. That is the common stock type anyway. I know they are nothing special. Why do you need to know out of curiosity.
Posted: May 19th, 2007, 4:57 am
by MX3ak
Well, thanks for reply. I need to know because if they were made with some kind of soft metal they would be consumed by Lpg, wich is the "gas" in feed my motor.
Lpg is very dry and not lubrificant like gasoline is. And Lpg heats the combustion chamber lot more than gasline. Then soft metal valves are rapidly consumed.
In some motors, like Honda, are soft valves and then Lpg users have to add a special lube called FlashLube so the valves can last longer.
Besides, they (soft valves) also need to adjust regulary the valves clearance, because of rapid consume Lpg mades on them. But there, we don't have that problem because K-series have HLA'a that are auto adjustable.
Posted: May 19th, 2007, 11:42 am
by JWMX3
so youre saying the the of alloy they are made of dosent concern you, its the hardness, and that could be anything depending on how they were heat treated when they were made in the factory
only way to find that out is to take a valve to a metallugry lab and have them do a hardness test
Posted: May 20th, 2007, 2:22 am
by tehbrookzorz
So the whole aluminum block and head isn't a concern?
Posted: May 20th, 2007, 6:03 am
by MX3ak
Good cooling system takes care of block.
Just the exaust valves I'm concerned for the reasons I posted before.
By the way, I think this could be a concern for peoples running high octane gas and constant high rpm.
Posted: May 20th, 2007, 3:29 pm
by hgallegos915
Theres a guy that runs on LPG gas already. Nothing bad will happen.
