cai problem
cai problem
I've read the how to on cai and I think i did everything but still having a problem.
Problem: turn the car on the engine light goes on and the engine sounds like its cutting and when i give it gas the engine dies out. also i can hear the intake sucking in a lot of air. its pretty loud.
i bought an intake for a 90-93 integra cut it so it fits just right. I left the bottom part of the box to the device that the tubes connnect into can be in their normal place like the how to says. Right now i just have a filter attached to the stock intake.
- ryan_Fuerte
check to make sure you plugged in the vaf.. also make sure there are no leaks between the rubber and the piping..
Mx-3 GSr : Rebuilt klde with 5spd swap, xtd stage 3 clutch, Magnaflow dual exhaust,Accord custom intake, kyb gr2 struts with eibach springs, civic dual halo projectors, black altezzas, white 15'' oz rims, rolling on dunlop street slicks.
http://www.cardomain.com/ride/2400330
Thats weird, I didnt have to do any of those procedures.. check for leaks and check the VAF sensorm its that black cone shaped thing.
-hec
