KLZE problems
war_spider
KLZE problems
Post by war_spider »
hello together,
I have some problems with my KL-ZE engine
on the one hand not exact all negative pressure hoses where they to be are, is there a KLZE installation manual for it?
on the other hand it gets simply not the power it probably should have.
when 3000 rpm it goes good - if the first VRIS folds operated
but after this it gone slowly to work and on the motorway after 160 km/h in the 5th gear its a long way to 240 km/h (more was not possible cause damn slow cars in my way yesterday)
but the VRIS controller work correkt i think
I have a curfed neck KL-ZE with KL31 controller, a stainless steel header and a 100cells race-kat
sorry for my bad English :(
greetz from Germany
-= loud pipes save lifes =-
KL-ZE inside!
PATDIESEL
Post by PATDIESEL »
There is a German MX-3 forum that you might have better luck with. No language barrier. I think I understand what you are saying, but try the German forum first. If you cannot find a German MX-3 forum then post back and surely someone here knows the URL.
war_spider
i´m a member in the german mx3 forum ;)
on my header there writed "KL 31 1A1"... and a curfed neck... is this a real 200 hp engine?
greetz
KL-ZE inside!
Custommx3
Site Administrator
Post by Custommx3 »
You could have a millena. What CAMSHAFTS do you have?
war_spider
i´m a n00b... where can i see which camshafts?
KL-ZE inside!
Custommx3
Site Administrator
Post by Custommx3 »
On the camshafts :)
See where it says "KL 31". thats your cam markings.
war_spider
tomorrow i put they heads away ^^
KL-ZE inside!
war_spider
i got KL01-3 and KL01-5 camshafts
whot does it means?
is my KL31 controller right?
edit:
http://www.mx-3quebec.com/swap6.htm
what means the "No. TB" ?
KL-ZE inside!
wyldside
Post by wyldside »
What readings do you get from a piston Compression. (Druckversuch auf allen Kolben?)
James Gosteli
X-Prez of MX-West
1992 Seal-Gray MX-3 GSR-ZE (KLZE 2.5L V6) :mrgreen:
1992 White MX-3 GSR-ZE (KLZE 2.5L V6) :( Worklog (Parting out)
1993 Blaze Red MX-3 GS - RIP :cry:
babyblueMX3
Post by babyblueMX3 »
war_spider wrote:i got KL01-3 and KL01-5 camshafts
whot does it means?
edit:
No TB means the number of the throttle body
RIP 400whp ZE-T MX-3
