mx-6 vs mx-3 tranny
Posted: May 12th, 2007, 9:48 pm
by comish71
anyone note a difference in the cases of the mx-6 vs mx-3 trannies. i was swapping out my mx-3 for mx-6 and it seems like it just doesn't fit right. externally, there are some subtle differences in the case which probably don't allow the shift rod and stabilizer rod to line up perfectly. i think the tranny is from a 94 mx-6. thanks.
Posted: May 15th, 2007, 9:32 am
by Chemical
I had this done by a mechanic and according to him it is a straight swap. I'll point the diiference in gear ratios does make a noticeable difference in acceleration too. At least a second off 0-60mph but you do get higher top speed and better mpg due to 5th giving you 70mph at 3250rpm instead of 3750 rpm
Re: mx-6 vs mx-3 tranny
Posted: June 20th, 2007, 8:08 pm
by m90daytona
comish71 wrote:anyone note a difference in the cases of the mx-6 vs mx-3 trannies. i was swapping out my mx-3 for mx-6 and it seems like it just doesn't fit right. externally, there are some subtle differences in the case which probably don't allow the shift rod and stabilizer rod to line up perfectly. i think the tranny is from a 94 mx-6. thanks.
i also wonder this???????????
Posted: July 20th, 2007, 6:25 am
by Presso_man
Im doing a KLZE swap very soon and have been thinking about using an mx6 trans, might as well while I have it all out?...problem is ive heard so many different things about mating the two together...hope someone with knowledge answers soon!
