Kf-ze turbo MegaSquirt config
Posted: May 8th, 2007, 5:11 pm
I was trying to figure out what king of tach pick up have kf-ze engine and what will work with the megasquirt
Are these the correct diagrams for kf-ze egnine?
http://www.astinagt.com/reference/BA/wi ... KF_ECS.jpg
I see only a crank sensor here. Is there a second pickup? A crank pickup is not enough for the MS in distributor mode.
Do you think the KF engine is close to the 1990-1997 miata install as seen on DIY autotunes site?
http://www.diyautotune.com/tech_article ... _miata.htm
