Ok i went on a road trip and broke down.. replaced dist, crank angle sensor, fuel inj relay, neg battery cable, and coolant is fine..
she is still hard to start, at least 3 cranks.. and I still got a cel ?oh and she isnt giving any codes.
oh while i was broke down i did a hei mod and she still didnt work.. so now i have a spare dist, that im gonna fully mod, but until i do so, does anyone have any ideas???
CEL FROM HELL
its not a fuel issue.. the only reason the relay was changed was, when i was broke down in B.F.N quebec, i jumped what i thought was # 10 on my thing a ma jig ...lol... under the hood and i fried the relay on my fuel.
plugs and wires are all good, sorry i forgot to mention that, but no i havnt changed the fuel filter, but its not starving at all, and no hesitation when she is running.
im thinking hmmm the bulb may accidently burn out...lol...jk
- PATDIESEL
There are only a few options really. Fuel issue, air issue, spark issue. So ohm the air meter and make sure it is in spec, test fuel pressure if you can, but replace the filter if it is old. They should acually be repalced about once every year, but I don't know anyone that follows that. Run some fuel system cleaner to make sure the injectors are clean. You might ohm them to to make sure they are ok. However, they could still be clogged partially and thus the spray pattern can affect the start up since the gas will not be atomizing properly. Then check the spark again.
- PATDIESEL
Forgot to mention, have your battery checked and make sure you are getting 12 volts when off and about 13.5 or more when running.
