99 Octane and Advanced Timing Deg?
Tommy D
Post by Tommy D »
Hello, i hava a KL31 ZE and a J spec KL31 ECU. In Japan they use 103RON octane i read, but in the US you guys have 95RON. In the UK the fuel to use is 99RON Shell V-Power.
Most peeps set the ZE to 10deg TDC i read but where should i set the timing running 99 Octane?
Is there a chart, I know the ECU can partially learn but im just after every last Bhp, lol
Any help would be great, thanks 8)
MX3ak
Post by MX3ak »
The timming should allways be 10deg TDC when idling at 650 rpm. Then ECU adjust timming automaticaly when acelerationg. Thanks to a knock sensor in the K serie, the ECU try to advance as much as possible until knocking occurs. Then it stops advancing or retard it as needed.
Since that, I think the higher the octane is, the far the advance can go.
I may be wrong, dont know for sure. I'm here for learning about this car as everyone else so...
K8 running LPG (Liquified Petrol Gas)
