Fuel Rail to Barb Adapter: 5-15 Avail
Posted: May 1st, 2007, 3:54 pm
This is for jeff..
I'm in a position to produce this item... Albiet in limited numbers..The plans will be posted free of charge in JPG and CNC-Ready DWG.. So if you have access to a lathe and hacksaw/bandsaw..and 2" metal...Mind a machine shop would charge MUCH more...
It allows a universal barbed Adjustable FPR to be used while removing the stock unit from the system..
They are a PERFECT slip fit on 1.6L DOHC and 1.8L BP Fuel Rails with an o-ring land for added protection..
$20+shipping is the cost...bout 1-1/2 hours work + metal...I think that's a fair price for the item after mild-googling...and that it's a specialty item for mx-3's..Which are hard enough to find any parts for...
Here are some pictures of the finished item:
**Any more made WILL have larger ridges and will be properly spaced to fit a small worm-gear clamp perfectly in between...Mine are a little thin and almost to close together...but functional...
I'm taking this in school, so it's up to my speed & hiding skills as to how many i can punch out before my teacher tells me to fak off and do his projects
Interested parties include:
-10secSim
-93_4Banger
-mx3optidrive
-10secSim
-93_4Banger
-mx3optidrive
