B6D Questions
Posted: April 28th, 2007, 3:11 am
Okay, so I've been searching for awhile now and would like to be pointed in the right direction with links or straight answers if you could.
First: I'd like to know where I can find Cam information, regrind info, new cam purchase, and are the Miata cams any better than the ones already in it from the MX-3.
Second: I've been trying to find a Header and realized I was just a few days late as I saw the one in the FS section and about cried, so if you have one or know where I can get one it'd be appreciated as Corksport no longer has them.
I plan on Turboing it probably a year from now, maybe longer, but I'm just trying to increase performance for the time being, I've already done plugs, wires, intake, and full exhast(except header).
I'm going to go to my local Pick n Pull to find a set of Cams, if I'm lucky enough to find a Capri or GTX I'll be turboing it sooner than expected, but at this point I'm looking for cams to do a regrind unless the Miata cams will give me a decent boost.
This motor is in a 91 323 by the way.
Any help would be appreciated in this matter.
Thank You,
MrH.
Thank You,
MrH.
