Quick Tire Size Question
Bochek
Post by Bochek »
Allright i picked up some Konig BrightLite 16's from GoodWinRacing.com
16x7 40mm offset.
There going onto a 93 RS.
I would like to stay close to stock tire maby a bit on the bigger side.
So what size tire?
- Bochek
Tunes67
Post by Tunes67 »
This has come in handy for me a couple of times.. hope this will help answer your question.
http://www.miata.net/garage/tirecalc.html
Tunes67
Bochek
Post by Bochek »
Yep, i have used this "calculator" before. Its a great tool.
Im still a little on the dumb side when it comes to what width of tire to go with.
What fits on a 7 inch wide wheel? 205? 215? 225?
- Bochek
wow that tire calculator is really useful! It gives insight to find how far off my speedo might be with aftermarket rims and tires!
thanks for posting!
ryan_Fuerte
Post by ryan_Fuerte »
closest tire to stock would be a 215/45 16
Mx-3 GSr : Rebuilt klde with 5spd swap, xtd stage 3 clutch, Magnaflow dual exhaust,Accord custom intake, kyb gr2 struts with eibach springs, civic dual halo projectors, black altezzas, white 15'' oz rims, rolling on dunlop street slicks.
http://www.cardomain.com/ride/2400330
Bochek
Post by Bochek »
got everything figgured out except.
who wide of a tire can i put on a 7" wide rim with a 40mm offset?
Whisper
Post by Whisper »
Wouldn't go above 215, or you might get too close to the strut.
Here's a better calculator, that gives you a visual representation and butt-load of other specs.
http://www.rims-n-tires.com/rt_specs.jsp
Oh, and as far as tire width that will fit, since tires flex, you can fit a decent range. Probably from 195 to 225.
