KLDE Swap Question(obd)
Posted: April 24th, 2007, 7:57 pm
by MX3parkerGS
Hi guys, most of you probably dont rec. my name. But I was frequently at this forum when i owned my 93 GS. I sold it about a year ago. (got into atv's). But like I knew would happen, I started to miss it. I just picked up a very very VERY nice cond. 94 GS(white). And this time, no more saying"im gonna swap, im gonna swap). I really am. The motor is coming from a 9? Mazda 626 from a local junk yard. Cant confirm the year, Im at work right now, cant check.
Now for the question. Ive been trying to refresh my memory, but just to confirm, if this 626 ends up being OBDII, that doesnt change the fact that I can use this 2.5 out of it, correct? Its just that I wouldnt be able to use this 626's ECU(that is w/o swapping whole wiring harness), correct? Or no?
Thanks in advance! Parker
Posted: April 24th, 2007, 8:06 pm
by Tunes67
Correct.. however.. the later model 626 engines (and millenia engines for that matter) came with solid lifters and applicable camshafts as well. So they are the more desireable engine.
Your likely in for a small pain in the arse when it comes to hooking up your wiring harness to the engine.. you may have to swap out some of your K8 sensors or even go junkyard diving for OBD I sensors from other KLDE engines. But that will definitely be a TON easier than trying to convert your OBD I car to a OBD II wiring harness and ECU. If I recall correctly.. you might have issues with your crank position sensor.. I know there was one sensor that was completely different between the OBD I and II sensors.. and I think it was the CPS but I admit I am not 100% certain by any means.
Congrats on the 94 GS.. Make sure you visit the Appearance forum and register your car color in the POLL there
Tunes67
Posted: April 24th, 2007, 8:42 pm
by MX3parkerGS
thanks for the quick reply! Didnt even know there was a "prefered" KLDE. So if this ends up being OBDII, i should most likley have all the sensors n what not that I cannont use off the 2.5, avaliable off of my 1.8. correct or no?
thanks again, Parker
Posted: April 24th, 2007, 8:47 pm
by Tunes67
As far as I know.. yes.. but be prepared for a bit of junk yarding if something doesnt screw in the same
(Just in case) Plenty of folks have done it so its not new ground or anything.. just gotta roll up your sleeves and get dirty.
If you run into a issue you dont know how to solve.. post up and I am sure there will be plenty of folks that have the solutions
Tunes67
