So um... quick question For a smart(ish) person:
taking off the heat shield, is that a bad idea?
And erm... is it bad if while attempting to take off the heat shields, the bolt heads break?
It's got some mad corrosion where it secures onto the pre cat down below and loves to go RATTLE RATTLE! Quite annoying.
So obviously the engine compartment would be hotter than usual without it, no? Would it be hot enough to make a difference? Plus, I like taking things off my car...
Exhaust Manifold Heat Shield, RATTLE RATTLE!
break off the bolts, and take it off, dont worry about it, i have never had one on my car.
