Swapped Injectors, Lost Power
Well, I swapped the fuel rails on my ZE from the old K8 ones that the mechanic put on to the rails I pulled off the straight neck manifold that came with the ZE. It started up and everything seemed to be working just fine. But when the engine is cold and I open the throttle up, I get nothing. It doesn't stall, it just accelerates very slowly. After the engine warms up to normal operating temps I dont have that problem, but it still seems to have less power than before. Any ideas whats going on?
- PATDIESEL
Could be a bad FPR or messed up injectors. I would put the K8s back on and send the KLs to be remanufactured.
same thing happen to me when i swapped injectors.
-hec
- neutral
I've had good experiences sending injectors for refurbishing and flow testing by these guys:
http://www.witchhunter.com/
Reasonable prices @$17 per injector and faaast shipping too.
-Jim
Wow - I've been trying to find somebody locally to refurbish my old set of klze injectors but no luck. That's a decent price!neutral wrote:I've had good experiences sending injectors for refurbishing and flow testing by these guys:
thanks for the link!
I fixed it by swapping them out for another set I had around.
-hec
