Direct-fit high flow cat
nightfire
Post by nightfire »
Does anyone make a bolt-on high flow cat for the K8? All I've found is OE replacements.
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
ryan_Fuerte
Post by ryan_Fuerte »
yah ebay has them for like less than 30 dollars.
http://cgi.ebay.ca/93-97-MAZDA-MX3-323- ... dZViewItem
-ryan
Mx-3 GSr : Rebuilt klde with 5spd swap, xtd stage 3 clutch, Magnaflow dual exhaust,Accord custom intake, kyb gr2 struts with eibach springs, civic dual halo projectors, black altezzas, white 15'' oz rims, rolling on dunlop street slicks.
http://www.cardomain.com/ride/2400330
ScooterBovine
Post by ScooterBovine »
I just bought that, thanks for the link! :D
No more MX-3.
ryan_Fuerte
you guys do know that they are illegal, and arnt a true replacment for a catyletic converter, they are basically just a glass packed cherry bomb but in a smaller version. Also using one of these there is a great chance that you wont pass you emmissions testing if your state or country has them.
-Ryan
nightfire
Post by nightfire »
Yeah I saw that one but I wanted to keep it street legal. I ran my escort with headers and a straight pipe for years and I always felt guilty about it. We don't have emissions testing here but..
- Gord
ryan_Fuerte
your best bet is to buy a magnaflow high flow cat, i got mine from crappy tire for like 80 dollars and tax. but then again it is a universal and you would have to weld on flanges.
nightfire
Post by nightfire »
ryan_Fuerte wrote:your best bet is to buy a magnaflow high flow cat, i got mine from crappy tire for like 80 dollars and tax. but then again it is a universal and you would have to weld on flanges.
Looks like that's the case eh. :/
Any idea where I'd find such flanges? Should any old 2.25" flange with the same bolt pattern work?
- Gord
ryan_Fuerte
sure thing!! any part store should beable to get them, I got mine from napa if you got them in quebec
Yoda
Post by Yoda »
nightfire wrote:Yeah I saw that one but I wanted to keep it street legal. I ran my escort with headers and a straight pipe for years and I always felt guilty about it. We don't have emissions testing here but..
Actually in Quebec we do have testing but there is no annual inspection yet because it has been delayed untill the people at the inspection stations are fully trained but it will only be a matter of a year or two. However if your car gets sent to inspection the SAAQ does have an emission test on the check list of items the vehicle has to pass to remain on the road. Right now it is up to the inspector to do the test and even then the results are only recorded and data sent to quebec city whether the car passes or not.
SstennizZ
Re: Direct-fit high flow cat
Post by SstennizZ »
Does anybody here know of an ebay shop that sells the "cherry bomb" like el cheapo cat converters that actually are direct bolt on fit on the GS? The pictures always show the two flanges in line (which they aren't on the GS) and never state GS or V6 os..
