Is this what a AC refrigerant with dye leak looks like?
tysoe
Post by tysoe »
These pics were taken from behind the plastic splash guard on the drivers side just regular light coming through no UV or anything.
Or is it something else? the wet stuff looks the color of coolant to me, the die in the AC is a bright yellow. Thought I'd get an opinion being new to working on cars.
The AC was recharged about 3 weeks ago and has definately been leaking , and the coolant resevoir is full, engine takes a few minutes to warm up etc.
Anyway, trying to find the AC leak and wonder if this is it?
It's on the wrong side of the car for the compressor, and looks to be coming from the large hose with the screw on fastner rather than the metal AC hoses.
lutos
Post by lutos »
yes that does look very much like PEG oil (the oil in the A/C) if u are concerned about it being cooland get your cooling system pressure checked and are you needing to add cooland? but cooland usually does not give a pattern like that
tysoe
Post by tysoe »
heh cool, looks like I have a good location to start figuring out where the leak is :)
I'm almost positive it isn't coolant. THanks man :)
Just cleaned it up and have to see if I can figure out where its coming from now :(
lutos
Post by lutos »
np
lutos
Post by lutos »
np
hgallegos915
Post by hgallegos915 »
Is that a hole on the line? also it could be antifreeze that is leaking slowly.
-hec
lutos
Post by lutos »
it way too brigt to be anti-freeze
